Posted By engineer on 12/17/2008 11:05 PM
Good job coming up with a test power supply.
Didn't you say earlier you'd measured 13.6 Vdc at the solenoid leads, yet now it only switches with an outside source of ~12 Vdc, so I'm still a bit confused.
I actually used a variable supply, it seemed like it was switching at about 14.5V, but when I replaced the connector (with 13.6V) it worked just fine. Maybe it was stuck and the little bit? Time will tell if there is deeper problem with the solenoid itself, or it was simpy poor contact in the connector. But I've cycled 2nd stage (from the thermostat) several times with repeatable results.
