How to tell if my Waterfurnace is working properly?
Last Post 17 Jan 2010 10:41 AM by geotek. 24 Replies.
17 Dec 2008 11:05 PM
Good job coming up with a test power supply.
Didn't you say earlier you'd measured 13.6 Vdc at the solenoid leads, yet now it only switches with an outside source of ~12 Vdc, so I'm still a bit confused.
project_xUser is Offline
17 Dec 2008 11:20 PM
Posted By engineer on 12/17/2008 11:05 PM
I actually used a variable supply, it seemed like it was switching at about 14.5V, but when I replaced the connector (with 13.6V) it worked just fine. Maybe it was stuck and the little bit? Time will tell if there is deeper problem with the solenoid itself, or it was simpy poor contact in the connector. But I've cycled 2nd stage (from the thermostat) several times with repeatable results.
18 Dec 2008 12:37 AM
I vote for the loose connector.
On several occasions I've driven as far as 500 miles, tightened one or two coaxial connectors a quarter turn or so, resolving a critical manufacturing control system's communication problems, and then driven home, billing each such customer $2-4k per my employer's rates. Customers are happy, and I stay well stocked in steak and beer without having to don coveralls and work a real job.
HerbertUser is Offline
16 Jan 2010 09:28 PM
This may be perfectly normal. At stage 2 the fan speed is higher than stage 1. meaning that there is a higher mass flow of air going across the heat exchanger. So while the temperature differential may be less, the total energy flow is higher. The best way to check is probably to measure the time it takes for a temeprature rise using stage 1 and compare it to stage 2 (from the same starting point under steady conditions).
geotekUser is Offline
Sometimes things get a little sticky inside the compressor when new.
The comfort alert sends 18 to 24 VDC to energize solenoid momentarily and then drops back for there to hold it in.
Be aware the 2 prong plug needs a firm seat to pass that voltage.
Sometimes a little coaxing is necessary to seat the plug.
People Online People Online: Visitors Visitors: 165 Members Members: 0 Total Total: 165
