Geo heat pump customers reviews
Last Post 08 Mar 2009 09:16 AM by SteveWV. 23 Replies.
SteveWVUser is Offline
05 Mar 2009 08:26 PM
I have a ART sytem.  It was installed in the fall of 2005 by my wife and I.  Design parameters are 90 and 10 degrees.  I used HVAC- Calc for my  heatloss-gain calculations.  I have 6-600' ground loops 5' deep spaced 8' apart single pipe.  I have  a 2500 sq ft 2 story house plus a basement, which I don't currently heat or cool.  I have two Tetco heat pumps, a  3 ton and a 2 ton feeding one duct system.  Installing the ground loops was a chore.  Broke the boom on a 5' ditch witch (lots of rock).  Spent six weeks on a rental backhoe digging trenches (broke at least 2 dozen backhoe rock teeth).  We finally got it finished the first part of November 2005.
Why did I do it myself?  We built the house, did the plumbing, wiring, laid cermaic tile and hardwood floors by ourself.  Paid a company to put in the original heating system, which were not happy with.  Hey, we can do geo ourself. That really wasn't our plan but....There was only 1 geo installer locally and we weren't impressed.  I spent a lot of time talking to Mark Ross at ART prior to deciding to do this myself.   Mark was always helpful and has a wealth of knowledge.
I replaced a  high efficency propane furnace (I think 100,000btu's). We only used the furnace by itself for a year. From what I remember we used 150 gallons a month of propane with the thermostat at 65. We put in a wood/coal stove after that and supplemented with the furnace when it got real cold.
Now the geo numbers.  I figure we use about 1000 to 1200 kwh a month for heat. I recently put my GSHP's on a seperate electric meter so I can be sure of actual usage going forward.  We leave the thermostat at 68. I live in eastern WV.  Right now my EWT 43 LWT 38.  entering  air temp 68 exiting 88.  In the fall with EWT 61 my temperature rise was 25 degrees.  When it's below 30 my 3 ton runs almost constantly and below 20 the 2 ton will cycle on as needed.
Final thoughts,   I would definitly do geo again, without a doubt.  Would I do it all again myself!  Tough call!
Cheers,  Steve
06 Mar 2009 12:08 AM
Thanks Steve.
sunnyfliesUser is Offline
07 Mar 2009 02:53 PM
Great post! Is your monthly usage an annual average?
Sunnyflies,  The figure for monthly usage of 1000 to 1200 kwh was for the 3 coldest months of Dec. Jan. and Feb.  I originally came up with the monthly fiqures by taking a month with no heat or a/c use as a baseline.  Then I would subtract that figure from my usage for the months heating portion.  This is just for the heatpumps.
    With my new electric meter 2/23 thru 3/7 I used 428.92 kwh total on the heatpumps.  HDD for those 12 days was 335.2.  The highest usage day was 55.94 kwh on 3/3, but it was cold, average temp was 21.5 degrees.  Average daily use for the 12 days 35.74 kwh.  That works out to 1072 kwh for 30 days use. This is just for the heatpumps.
I hope that answers your question,  Steve
People Online People Online: Visitors Visitors: 328 Members Members: 0 Total Total: 328
