Desuperheater Tranquility 27 Question?
Last Post 27 Nov 2008 11:27 AM by engineer. 6 Replies.
Scott9345User is Offline
25 Nov 2008 01:49 PM
Hello, I'm installing a Climatemaster Tranquility 27 5 ton unit  closed loop w/  two 500 ' wells with 11/2" pipe 50 miles north of NYC.
My question is:  What is the best way to utilize the desuperheater?  I have an existing 80
                          gal electric water heater.
1)  Place a smaller storage tank in series with existing water heater?
2)  Place a storage tank and install  a whole house on demand system?
3)  Use only my existing water tank?
Thank you for your information.
25 Nov 2008 02:35 PM
Place a large storage (at least 80 gal) tank in series with the existing water heater.
25 Nov 2008 02:50 PM
Thanks for the quick reply.  Does the storage tank need to be hooked up to electic, or just insulate the tank and hook it up in series to my electric 80 gal tank?
Thanks your info is really an asset to this forum!
25 Nov 2008 02:54 PM
The storage tank does not need to be hooked up to electric, just insulate the tank and hook it up in series to the electric 80 gal tank.
Good Luck
25 Nov 2008 04:36 PM
Probably an elementary point to make, but the preheat tank (the one plumbed to the desuperheater) is placed before or upstream the main tank.
27 Nov 2008 11:11 AM
Thank you for the information.  Does the concentric fitting go on the 1st storage tank or on the maintank hooked up to the electric?
If I understand correctly that the concentric fitting flow water to and from the desuperheater, it goes on the 1st storage tank, commonly referred to as a preheat tank
People Online People Online: Visitors Visitors: 234 Members Members: 0 Total Total: 234
