Any positive experiences with tankless
Last Post 14 Dec 2008 06:03 PM by geo fan. 4 Replies.
geo fanUser is Offline
14 Dec 2008 03:25 PM
Im considering adding a booster tankless hotwater heater, but the only one advirtised to act as a booster, or supplemental is the seisco electric. Which looks realy bad when reading cust. reveiws. Any positive experiences with specific brands , or is it not even worth it , Curruntly the upper element is the booster and I realize how that will effect the staging , when a second tank is out of the question ( space ) whats best?
14 Dec 2008 05:08 PM
I think any tankless should work well when fed from a preheat tank heated by a desuperheater - not sure if that is what you are getting at here.
14 Dec 2008 05:49 PM
The only experience I have is with the Bosche LP tankless , but according to the rep from our geo manufacturer , this wont work because then sensor that turns them on requires inlet water around 80 F or lower to turn on .As is the case with most whole house units , They recomend Point of Service units applied to the whole house , the only problem I have with that is they all look like POS ( not point of service ).
Any way my point is , Am I better off using the upper element to boost the temp ( even though its not right ) or are the savings significant enough to take a risk on one of these units
14 Dec 2008 06:01 PM
When I said "any tankless" I was drawing on my experience with electric, not gas. I can't comment on gas units.
The element temp differential method offers limited potential for successful application of a desuperheater to a single electric storage water heater. I've commented at length on this option elsewhere here so won't repeat myself now. I doubt the economics of that option would support a reasonable payback period of the increased cost of a system with a desuper.
Thank you
People Online People Online: Visitors Visitors: 248 Members Members: 0 Total Total: 248
