The problem with all heat pump thermostats is none are designed for geothermal ( even the ones supplied by a geo manufacturer )
I would recomend calling back the installer ( who did nothing wrong besides not being creative enough )
I suggest do NOT change the aux setting on the t-stat but instead add a 1 hour delay on make time delay relay to the aux heat wire.
<script src="http://www.google-analytics.com/urchin.js" type=text/javascript>
</script>
<script type=text/javascript>
_uacct = "UA-2096641-5";
urchinTracker();
</script>
Single Shot Time Delay Relays
T2 Series |
This will greatly reduce your aux usage . simply changeing the setting on the t-stat to a different setting will give you another set of short falls ( like kicking on your aux when you adjust the temp ) a problem you curruntly dont have . I would also have them double check a call for aux is turning on your heatpump , if there is not a after market rib relay to turn on your heatpump when your aux turns on, the currunt setting on the t-stat has a compressor lockout below 20 ( thinking you have air to air ) this must be over bypassed
