For basis of comparison because my home is approximately the same size at 1950 sq ft and 70 years old, I'll throw in my data:
My Nov/Dec bill (mostly Dec) came out to be 1572 KWh, previous years I averaged around 450KWh, so this shows an increase of ~1100KWh on my electric bill. I installed submeters and I can confirm that my geo system in that same timeframe actually used 1158 KWh's.
Now, in that same timeframe I had 1035 heating degree days (HDD) here in the Albany, NY area, so I average about 1 KWh per HDD. (last year I had 1054 HDD's so not too much of a difference).
Just so both of you can compare I did a quick search of your areas and found weather stations in the approximate locations where you live:
Iron Mountain, MI (I know it's not WI, but this was the closest to NE WI I could find quickly)
In December 2008 you had 1603 HDD's
In December 2007 you had 1450 HDD's
Morristown, NJ (again, I don't know if this is near you, but I looked for stations in Northern NJ)
In December 2008 you had 954 HDD's
In December 2007 you had 932 HDD's
I have found that HDD's is a good way to equalize for temperature difference in different locations. Of course this does not help to equalize soil conditions, type of loop, etc.
Just more data to digest....
