I didn't want to hijack the other thread
"Humidity out of control--help" as I don't have a crawl space but rather a usually normal RH basement. New WF Envision 3ton startup was Aug 1st. Unit has been running fine and I've been running with the fan on ON but just switched to AUTO tonight after reading the other Humidity tread. I'm in the MetroDC area and when we had the August heat the house was set to 74 and while the temp is fine the RH is 60-65% both 1st and 2nd floors (have three electronic temp/RH units placed around)
The GSHP Installer's plumber was out last Friday and used a stick/numchuck looking instrument and would swing it around the one of the air-return ducts. First was at 74degs and then again after the Stage-2 fan was on for 20 minutes.
What RH number should I expect? I put in new efficient windows last winter so I don't think the AC runs as much but I keep it at 73-74 24/7 since Aug 1st.
Thanks for your help.
Chris
[email protected]
