2nd Stage Operation
Last Post 09 Nov 2009 08:59 AM by joe.ami. 5 Replies.
sx700rUser is Offline
04 Nov 2009 11:18 AM
Don't be afraid to call me a dummy, but how do you know when your heat pupm kisks in to the 2nd or even third stages. I have an Econar 8 ton unit.
Rick
BergyUser is Offline
04 Nov 2009 03:38 PM
Most units will give no indication of first or second stage operation. Some thermostats will indicate third stage operation by indicating "Aux Heat".
Bergy
stevecazUser is Offline
04 Nov 2009 10:28 PM
This is exactly why I installed 24v LED lights inline with the wires to the each valve controlling 1st and 2nd stage, for both units. The LEDs protrude through drilled holes in the plastic junction box where I made my connections between valve wires and 18 gauge t-stat wires running back to the geothermal unit. They come in almost any color, but I chose green for on. I think I paid $7 for a lot of 10 of them, prewired with 12" pigtails.
Very easy to see if 1st or both stages are on this way, although maybe you're looking for a way to tell in the living area without having to go to the units. I've found I can tell just by sticking my hand at the vent, 2nd stage is perceptibly warmer air.
My T-stat, and I would guess most used for geothermal, can be set to instantly go to 2nd stage if the set-to temperature is X degrees above the current temp, and it can also be set to turn on the 2nd stage after XX minutes if the set temp hasn't been reached in 1st stage. I don't have a 3rd stage (electrical resistance coil) but my T-stat does have a setting to show an indicator for that.
CHuntMDUser is Offline
05 Nov 2009 07:11 AM
My new WF Envisions came with a WF thermostat (looks like a Honeywell unit  ;) and it shows Stage1  or Stage1+Stage2 2when in cool or heat mode.
To get on emergency Heat I have to press the on/cool/heat/emergency heat/off button
CH
06 Nov 2009 07:12 AM
I have hourmeters (Redington ~$32) on each stage. decimal point on meter blinks when stage is active
8 tons?
Second stage should also have discernably higher blower speed.
Is there a reason besides curiosity you are trying to tell?
joe
People Online People Online: Visitors Visitors: 445 Members Members: 0 Total Total: 445
