I purchased a Climate Master Tranquility 27 "4 ton". We decided to go with a split system and use our two year old Hi eff propane furnace as the blower source as well as have back-up. The other option was an electric in the duct heater. The unit itself is very quiet but it seems like the coil they put in the duct has a vibration when the geo is running. There is no vibration when the fan is running by itself. This system is a two stage + propane back-up and I was told that the second stage would only turn on when it is really cold. So far we have been hovering around the freezing point and it is already going into the second stage.
In stage one the system draws 10Amps at 240V for the Geo and 6 Amps for my furnace fan.
In second stage it draws 14Amps at 240V for the Geo and 6Amps for the furnace fan.
I work in the electrical industry. I am going to connect a power quality
analyzer to this system for one week and record how many times per day the system cycles on as well as the total KWH for a one week period with outside temps. I will post my results latter. The system has only been running for two days at this point so it hasn't been enough time to see if it was worth it.
I am a bit nervous at this point.
Thomas
