Power outage planning
Last Post 01 Apr 2010 08:41 AM by geome. 29 Replies.
WF_Inc.User is Offline
22 Mar 2010 09:16 AM
Geome,
This information may be helpful to your contractor when sizing a generator.
WaterFurnace International, Inc.
Attachment: Generator_Sizing_Sheet.pdf
22 Mar 2010 10:00 PM
That's impressive - being able to start a 5 ton heat pump with a 7 kw generator is astounding.
Does Intellistart come with any efficiency penalty during steady state operation?
Is it expected that soft starts will aid in compressor durability?
If widely adopted the technology could make whole-house standby generators much more feasible, and those houses much more comfortable during long outages.
I hope it would spawn production of quiet, high efficiency 1800 rpm 4-pole generators in smaller kw sizes.
A smart transfer switch could sequence other big loads in the house (range, dryer, water heater, heat pump) so as to allow limited operation of those loads during an outage. It might be configured to drop the range and water heater during a heat pump start and then return them to service.
Other possibilities include dropping electric storage water heater voltage from 240 to 120. That cuts wattage by 75%, quadruples recovery time, but still makes some hot water available during an extended outage.
23 Mar 2010 09:32 AM
engineer,
The IntelliStart does not penalize efficiency during steady state operation.  This feature assists the compressor circuit during start up.  As for aiding in compressor durability, we are not aware of any testing that has been done to confirm this; however, many compressor failure modes can be related to startup.
23 Mar 2010 11:26 AM
Does sound great, but I would want to see independent verification of such low starting loads.
Very nice to have WF posting here.
600rmkUser is Offline
23 Mar 2010 12:59 PM
Maybe a good time to also note that if you have a backup generator for your house, it's probably a good idea to let the power company know so no one incidentally gets hurt servicing a line that they think isn't energized.
CHuntMDUser is Offline
23 Mar 2010 01:34 PM
Here is the US all 50 states have adopted some form of the National Electric Code. And while I'm not a electrician a generator wired into the home's wiring is required to have a disconnect switch (basically it cuts the main breaker) so you can't send your self-generated 110/220 down the line. I'm having a Intellistart installed on April 2nd in my WF Envision 3ton.
OnaUser is Offline
25 Mar 2010 08:55 AM
CHuntMD ~ Are you installing the intellistart for the sole purpose of being able to better run a generator in a power outage? I'd love to hear about how it goes... i.e. what size generator you can use with the intellistart and how difficult it was to install (for your contractor).
I was thinking of an intellistart with a generlink set up for my situation, but I'm still in the beginning of the planning process.
25 Mar 2010 09:04 AM
Future planning for a NG fed generator but I do like the idea of a smooth start for motors. I'm entering the shoulder seasons here in Wash DC and just last weekend I heard the hot-water tank kick in after a shower. Dec/Jan/Feb I used 8 therms of NG total.
25 Mar 2010 10:12 AM
Now that we have the attachment, the generator size needed is dependent on the generator overload characteristics. A safe value should be 2x the normal motor draw (a great improvement over 5x or 6x). Ie, I'd get a 10Kw generator for 5 tons - cutting it too close could be an expensive mistake.
geomeUser is Offline
Thanks WF! Sorry for the delay in responding. I've been out of town.
People Online People Online: Visitors Visitors: 138 Members Members: 0 Total Total: 138
