GT QUERY - Caribbean
Last Post 01 Mar 2010 07:26 AM by joe.ami. 2 Replies.
WhittakerjUser is Offline
28 Feb 2010 09:50 AM
http://www.greenbuildingtalk.com/tabid/53/afv/topic/aff/21/aft/76625/Default.aspx
Can anyone provide feedback on the feasibility and typical cost of a Geothermal system, keeping in mind:
a) Im building on "filled" land (marl & other aggregates) right on the water (canal) so Im not sure if the thermal properties or depth requirement are doable.
b) Performance wise Im not sure how reliable it would be to cool a home in 80-90 degree temps year round (as compared to HVAC). Im in Carribbean
c) Im not familiar with what would be an optimal setup of a GT system in terms of materials, design, etc.
28 Feb 2010 10:46 AM
High efficiency air source may be a better bet in your circumstances, although if you are near ocean, salt air tends to quickly corrode outdoor unit aircoils, a significant advantage of geo.
Horizontal systems here in Florida are said to need 1000' per ton - I've never done one. Wet soil is helpful for heat transfer, may hinder installation. Your deep ground temp may be 75-80 F, another important design consideration.
Some air source brands may be better at resisting salt air than others. Local experience might me useful.
Best bet is to start with checking local listings for a pro near you.
The things I'd have you look at are vertical or open loops or DX.
You can try IGSHPA (International Ground Source Heat Pump Association) for a pro listing.
IMHO the best payback for geo is in heating dominated climates, so Curt's advice on air source is worth looking at. If there is no ocean/corrosion reason to prevent use of an airsource unit you might find the numbers are significantly lower to purchase and only slightly higher to operate.
Good Luck,
Joe
People Online People Online: Visitors Visitors: 190 Members Members: 0 Total Total: 190
