Hey, Does anyone have a Rehau manifold installed? It would have red caps for turning the flow on/off and then little gpm gauges, one for each loop. It probably has at least one temperature gauge, too, probably analog. I'd like to compare the readings I'm getting with mine to someone else?
If you have a similar type manifold, I'd love to hear from you, too. Either privately, or via posting.
Thanks.
