I have a (WaterFurnace) I noticed this morning the fault led was on, when I went to look at ther furnace control panel
I saw the the (Hi Pressure) Led was on. I tried to reset a couple of times but no difference. The manual says It's an air flow problem but the filter is new. It also says that it could be hi pressure in the cooling system but we don't use the air much and it's in heating mode. The fan runs fine,lots of air coming through the registers. I'm thinking a faulty sensor ,any one have any ideas.
