WaterFurnace run time
Last Post 18 Jan 2012 02:09 PM by SkyHeating. 6 Replies.
Michel StarenkyUser is Offline
16 Jan 2012 08:02 AM
Quick info. 6 Ton Waterfurnace Envision, Waterfurnace thermostat.  All indicators working well. Outside Temperature 10F. Thermostat set at 69F. Worked through 67F at Stage2, 68F at Stage 2, 69F at Stage 1. It took five hours to do its run time.
Is there anything amiss? Is there a minimum/maximum run time?
16 Jan 2012 08:33 AM
I don't know what is refered to by "do it's run time".
Design dictates pct of the hour a system will run. In my AO winter lows are 1-6F depending on whether home is closer to Detroit or Lansing. Therefore balance points would be in the teens (point at which auxiliary heat must contribute) and run times would be about 100%/hour. In fact they might hit 100%/hour in the high 20's or low 30's (though rarely leaving 1st stage).
Now system should be cycling between first second and third stages for best efficiency. If you were running on aux. the whole time there is a problem.
Next you may want to ask installer for a bin analysis of your design. This report will show hourly run times based on ambient temps.
16 Jan 2012 09:59 AM
I mean when the furnace clicks in and the time it stops.
ChrisJUser is Offline
16 Jan 2012 11:06 AM
Nothing sounds amiss for 10*F outside.
Why was temp 2 degrees below set point? Are you setting back temp at night? I just leave my stat at 68*.
ChrisJ
WF_Inc.User is Offline
16 Jan 2012 01:15 PM
Michel Starenky, If you feel your WaterFurnace unit may not be operating properly, we would suggest contacting your WaterFurnace dealer or HVAC contractor to discuss these concerns. If our assistance is needed, please have them contact our technical support staff. We will be more than happy to work with you and your contractor. WaterFurnace International, Inc.
docjenserUser is Offline
18 Jan 2012 03:39 AM
All sounds well to me....
SkyHeatingUser is Offline
Longer run times are often better, sounds like its sized and working well as long as your loop EWT's are staying up.
People Online People Online: Visitors Visitors: 237 Members Members: 0 Total Total: 237
