Geothermal Heat Pumps
Hour meter for compressor time
Last Post 04 Feb 2012 10:40 PM by
engineer
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
DickRussell
04 Feb 2012 11:25 AM
I have a CM Tranquility 27, 2-ton unit. As a less expensive way of gathering some info on how much the unit spends in operation, I was thinking of adding a simple compressor cumulative runtime meter, connected to the compressor contactor. Any thoughts on that?
joe.ami
04 Feb 2012 11:34 AM
You can monitor that or Y1. amp draw would be could to know as well.
engineer
Very easy to do with Readington LCD hourmeters. Model 3410, around $30. I have one each on Y1 and Y2. They work fine on 24Vac - no need to make high voltage connections
I also use them to totalize run time on water heater elements - same meter works on 24 Vac or 240
Membership:
croccohvacusa
People Online:
