Engineer,
I believe the latest article I have found on the internet is
http://www.climatewell.com/Document..._Paper.pdfIt shows that energy savings on cooling is 100%, heating is 50% and DHW is 100%.
I ask about this system because one of my clients has contacted the company to check on availability and cost. I read somewhere that the cost will be 2.5 to 3 times more than an air-to-air heat pump which will probably make it cost more than geothermal. But if the performance is really there, then it may be worth the extra cost. Reliability should not be too bad since they claim no moving parts.
I have read several articles on the internet but have not talked to this company. From what I read, this system will work best in hot climates that need a lot of air conditioning. That is why Spain became the test site instead of Sweden where it was invented.
Contact info for their USA rep is listed on their web site.
