Posted By DGF on 10 Mar 2012 01:04 PM
Copper pipe corrosion appears to be a non-issue the majority of the time.
HDPE pipe corrosion is guaranteed to be a non-issue ALL of the time.
No ifs, no ands, no buts, no pH tests, no contractor judgement calls.
I'm curious to know where the water pump actually adds value.
It eliminates a potentially catastrophic point-of-failure. IMO, a very
small price to pay for bulletproof reliability of the least accessible
subsystem. (Curiously, I've heard no one expressing "concerns"
about the circ pumps in old-school hot water radiator systems.)
I'm guessing there's some solid reason ...
- Limited in-ground heat exchanger size -- due to oil-return issues.
- Large quantities of refrigerant = code/safety/leak-detector issues.
- No possibility of factory-sealed, factory-tested refrigerant system.
