Questions from a geothermal newbie
Last Post 16 Mar 2012 08:31 AM by jonr. 25 Replies.
LoobyUser is Offline
08 Mar 2012 10:21 AM
Posted By DGF on 07 Mar 2012 01:40 PM
.... 2 mechanical systems (a water pump and a compresser) ought to be more
prone to fail, and lead to additional maintenance, then just a compresser alone.
That logic is fine IF the systems being compared have similar probability
of failure AND similar cost/consequences in the event of failure.
A heat-fused HDPE loop is about as inert as anything I can think of,
and certainly less susceptible to corrosion/leaks than buried copper
pipe. Yes, the circ pump is a potential point of failure -- but pump
replacement is a simple repair that won't break the bank.
Looby
DGFUser is Offline
10 Mar 2012 01:04 PM
Apprecitate the feedback, and explaining what you meant, docjenser
It really is not a big deal going through another heat exchanger and to have a circulation pump on it. Yes, there is an efficiency penalty, but again, the W-A heatpumps seem to run at a higher COP despite the addition of the second heat exchange. I don't think the ice is an issue. Water sourced systems freeze the ground all the time, too. The issue is that the ground cannot keep up and is not 25-30F but 15F or less, killing efficiency and possibly compressors.
Copper pipe corrosion appears to be a non-issue the majority of the time. Thats what I've read anyway. Seems like it could be ruled out as a problem with soil acidity tests, whatever the case.
Your points, while fine, just point out why a water pump is "not all that bad". I'm curious to know where the water pump actually adds value. Or in other words, sure - maybe it simply will never be a problem - but I don't yet grasp why having it in the first place means anything, vs not having it at all.
I'm guessing there's some solid reason, and not just that 98% of everyone else does it. Underground refrigerant issues, or perhaps compressor issues on larger scales?.
11 Mar 2012 11:16 AM
Posted By DGF on 10 Mar 2012 01:04 PM
HDPE pipe corrosion is guaranteed to be a non-issue ALL of the time.
No ifs, no ands, no buts, no pH tests, no contractor judgement calls.
It eliminates a potentially catastrophic point-of-failure. IMO, a very
small price to pay for bulletproof reliability of the least accessible
subsystem. (Curiously, I've heard no one expressing "concerns"
about the circ pumps in old-school hot water radiator systems.)
I'm guessing there's some solid reason ...
- Limited in-ground heat exchanger size -- due to oil-return issues.
- Large quantities of refrigerant = code/safety/leak-detector issues.
- No possibility of factory-sealed, factory-tested refrigerant system.
11 Mar 2012 11:35 AM
With HDPE corrosion is a non-issue 100% of the time.
I think it does, while no one discusses it, Looby touched on how inexpensive circ. pump replacement is. Would you expect a refrigeration circuit often 1,000 feet longer (than water source equipment) improves the life expectancy of compressor? Would you expect it costs more to replace a compressor than a fractional horse circulator?
DX does not take away the circulation of a transfer agent through ground loops it simply uses a larger more expensive (to purchase/replace/operate) pump (compressor).
DGF, I have created a seperate thread to once again sum up the short-comings of DX as it is lengthy.
11 Mar 2012 10:33 PM
It is easier (less pumping power required) to pressurize and send an incompressible liquid down a long pipe than to do the same with a compressible gas (refrigerant)
Maybe someday someone will make a DX system that uses HDPE or PEX pipe and a low cost propane mix refrigerant. All external to the home (for safety reasons).
People Online People Online: Visitors Visitors: 249 Members Members: 0 Total Total: 249
