Posted By jonr on 02 Apr 2012 10:19 PM
Sounds like you are alluding to another myth - that restricting the
flow through a pump increases its power draw (it decreases it).
Sometimes yes, sometimes no. Pumping power is a function of
flow rate, pumping head, and pump efficiency -- which itself is
a function of flow rate and pumping head.
pumping power = flow_rate x delta-P / efficiency
...the mythology you allude to is apocryphal,
Looby
