Posted By jwp on 19 Jan 2013 07:26 PM
We had our hot water heater looped into the system so the pump circulates the HWH water through the synergy unit.
Tell us more about this? While correct ductwork sizing is important it is not, unless off to the extreme, usually not the reason why there are not enough BTUs delivered to your space. If you are moving less air through, that air will become hotter. The overall BTUs are less, but usually not more than 5-10%.
