Posted By arkie6 on 20 Jan 2013 12:33 PM
I would bump up the stage 1 differential to at least 1 deg F to reduce cycling of the unit and save more $ in energy costs.
Done.1st stage now at 1 degree, 2nd stage at 2 degrees and Aux heat at 4 degrees.
I've also set the fan to intermittent with a run time of 15 minutes and an off time of 40 minutes to try and circulate the air when the unit doesn't run for an hour.
It's 52 degrees now in south central PA, but a cold front is expected shortly and we are expecting lows in the low teens the next few days.
Can't wait to see how the unit performs.
