Posted By chrisbiker on 05 Apr 2013 08:47 AM
All homes I have seen up here, boiler/rads, central ASHP/GSHP, underslab/hydronic, whatever, run shockingly(lol) too dry in mid winter without humidifiaction being added by some means. Outdoor dew point air in the teens/single digits gets in and just drys the place out. This is on typical homes and that is what I am referring. Not homes of energy experts who do all the proper stuff to get the shell tight.
Again, that's primarily a ventilation rate/infilrtation issue. Outdoor dew points are typically in the teens near me, but even at 20F dew points you're on the low thin wedge left side of the
psychrometric chart, where even dramatically lower dew points have neglible effects on the grains/lb. of moisture content in the ventilation air, and the amount of "makeup moisture" necessary to achieve a comfortable & healthy 35-40F dew point. Look at the grains/lb scale on the right edge of the linked-to chart.
At a 40F dew point the moisture content of air is about 35 grains per lb of air.
At a 20F dew point the moisture content of air is about 15 grains per lb of air, thus you need 20 grains of make-up moisture to hit the healthy-comfortable range.
At a 0F dew point the moisture content of air is about 8 grains per lb of air, so you need about 27 grains of make up.
Even at polar-arctic -100F dew points the difference in makeup moisture required is barely double what it is for +25F dew point air- it's just not that big a difference. (Just how far "...up here.." are you , really?)
Even if you're at the north pole, it's not very different from being in Worcester MA in terms of how much moisture needs to be added to the ventilation air, but let's run the comparison on the more temperate climate of Edmonton Alberta for yuks:
The mean January outdoor dew point in my Worcester MA neighborhood is about +15F or ~12 grains per lb, to Edmonton AB's +5F or ~9 grains per lb. according to weatherspark.com datasets. Those are shortfalls on the ~35 grain "healthy air" level of 23 vs 26 grains, respectively, not all that different in terms of how much ventilation/infiltration would make it too dry indoors. At a given rate of humidity input from people & plants/bathing etc I'd only have to back off my ventilation rates to 23/26 (88%) of my current levels to achieve the same indoor humidity in Edmonton that I'm getting in Worcester. That's not a very big change in tightness requirements, and definitely not super-tightness levels. Is it colder and drier in Edmonton? You bet! But it' doesn't make much much difference in how much moisture is lost out of the house maintained at human comfort & health levels.
And I'm not living in one of the "...homes of energy experts who do all the proper stuff to get the shell tight..." by any means- I've just fixed the biggest and most obvious holes left over from the circa 1923 timber-framed construction, and pumped some cellulose into the plank-sheathed never-tight wall cavites (or at least most of 'em.) I'll be blower-door testing the place at some point later this year as I work out some of it's less-obvious issues, but the interior RH as-is never drops below 30%, even during cold snaps. Even a half-assed stab at air sealing a house with plywood or OSB sheathing & windows newer than my double-hung antiques would be tighter than my house. (In most houses it's just not all that hard to hit under 3ACH/50 with even a modicum of effort, which is why it's the new standard for IRC 2012.)
Bottom line, it's the ventilation rate that dries out the place, not the heating system (though air handlers can drive infiltration rates way up on leaky houses), and the right solution for the benefit of both humans & building is to tighten up the place, not pumping moisture into the air with humidifiers. (And at 0.18 BTU per cubic foot per degree F that adds up to real energy savings as well.)
