bryceb
| 24 Dec 2017 09:05 PM |
Greetings, I had a new system installed in late fall and was wondering if it is possible to run out of heat from the ground loop. I am located in Manitoba Canada and it can get very cold here. Currently -30c.
System is a 4 ton waterfurance versatech
1800' of 3/4 pipe. 3- 300' trenches at 8' deep
100' of 1.25" from heat to loop header (50' out and 50' return.
currently the entering water temp is 2c and leaving water temp is -2c.
Should I be concerned the ground temp is already so low?
I am having no problems keeping the house at my desired temps just a fear that I will be making permafrost out in my loop. I am freeze protected to -20c with my loop fluid. (methanol water mix).
Any thoughts? |
| 25 Dec 2017 04:02 PM |
Yes, it's not unheard of to be "under looped". On the other hand, you may find that it stabilizes just below 0C entering (due to the latent heat of freezing). |
bryceb
| 26 Dec 2017 04:20 PM |
It does seem to be holding at about 0c entering and -5c leaving currently. There is a terrible cold snap here currently with daytime highs of -27c and lows of -33c at night and it is having no problems at all keeping the house warm. I understand I am maybe a little small on my loop at 1800' for the 4 ton but I also don't feel I am running anywhere near the full capacity of the 4 ton as my run times are 30-40 mins out of 1 hour.
Would it have made a difference if the system had been installed in the spring so I would have had all summer to put heat into the ground before I started removing it for winter or would the amount of heat absorbed into the ground not really play a roll in the winter heat cycle? |
| 26 Dec 2017 10:10 PM |
Both settling of dirt around a new loop and heating of the ground with summer AC have some effect. I wouldn't want to guess how much.
Looks like that unit has a lower limit of -1.1C EWT. I expect that you are going to have a problem staying above that. |
bryceb
| 27 Dec 2017 03:16 AM |
I was pretty sure the freeze alarm was set at 15f but you're saying it will have trouble operating below the -1.1c? |
docjenser
| 18 Feb 2018 12:30 AM |
As long as you have good flow, the EWT should not be the problem. You delta T of 5 degree C indicates that the flow is a bit on the low side, you are pushing all the flow for a 4 ton unit through 3 parallel loops, 4 or 5 parallel loops would be better. Also your heat pump is a commercial unit, any reason for that? Not the most efficient one out there either. The lower limit is not -1.1F, but low temp, low flow, and not the best quality unit might getting the limit closer to you. But usually -3 to -4C EWT don't bother me too much, you seem to be well above it. |
bryceb
| 19 Feb 2018 03:33 AM |
Well it’s almost 2 months later and still holding at 0 ewt. The reason for the commercial unit was cost, I got a price I couldn’t refuse. This winter compared to last has proven so far to be using about half the kw as last year on electric furnace. I should save about 1000 dollars this winter in heating costs so as long as I have no component failures I will be payed for in 10 years (fingers crossed) |
docjenser
| 21 Feb 2018 08:34 PM |
If your loop is still at 0 degree celsius, it means it is adequately sized and performing well. Enjoy your geo system. Your geo unit should run with a 300-350 % efficiency over an electric furnace, this winter seems to be colder than last year.... |
| 21 Feb 2018 08:57 PM |
Only when the ground loop is less than 0C does the capacity start to fade. It's a "magic number"/ Ground water above 0C has a specific heat of ~4.2 joules per gram per degree-C of temperature drop, but at 0C liquid water has a nice 334 joules per gram heat of fusion to overcome to turn it into 0C ice. But once frozen the ice has a specific heat of only 2 joules/gram per degree-C, so it gets colder faster, with only about half the thermal mass to draw from than when it is in a liquid state The specific heat other components of the soil don't change very much with temperature- they aren't undergoing the phase change that gives the ground moisture the very high apparent-mass at 0C. |
bryceb
| 24 Feb 2018 03:29 AM |
Great explanation about latent heat, I knew about it in btu of 144 btu from water to ice but never really thought about it in this application. Thanks |
