Geo Pump not heating
Last Post 19 Dec 2019 11:02 PM by DickRussell. 2 Replies.
stuartsaward1970
| 18 Dec 2019 02:24 AM |
hi, my Climate Master Tranquil 27 has just stopped heating.... I have 2 units, both feed off the same well, and one of them is working, so i think i could eliminate the water supply as an issue.... im battling to find service support in Mass, anyone have any ideas on what could be a common problem.. thanks! Stuart |
ChrisJ
| 18 Dec 2019 01:35 PM |
Need more info. "I have 2 units, both feed off the same well, and one of them is working, so i think i could eliminate the water supply as an issue...." Is there a plumbing valve for each unit that opens when heat is called for? Does the unit try to start then shut off? does it run but no warm air comes out? |
DickRussell
| 19 Dec 2019 11:02 PM |
The CM T27 circuit board will have a flashing error code that indicates what it believes is going wrong. Remove the bottom access panel and swing out the board. There will be a number of flashes on an LED on the board, a pause, then a repeat of the flashing. Count the number of flashes and let us know what it is. I have the Technical Guide manual for that unit, as I have the 2-ton model. |
152 |
152 |
