evaporative coolers
Last Post 16 Aug 2007 05:44 PM by billmh. 1 Replies.
13 Aug 2007 08:59 PM
Anyone have experience or input on the indirect evaporative coolers as a cooling alternative?
http://www.nbnnews.com/NBN/issues/2007-08-13/Research/index.html
Indirect, or two-stage evaporative coolers do not add humidity to the air, but they cost more than direct coolers and operate less efficiently.
Two-stage evaporative coolers combine indirect with direct evaporative cooling by passing air inside a heat exchanger that is cooled by evaporation on the outside. In the second stage, the pre-cooled air passes through a water-soaked pad and picks up humidity as it cools.
Because the air supply to the second stage evaporator is pre-cooled, less humidity is added to the air, whose affinity for moisture is directly related to temperature. The result, according to the manufacturer, is cool air with a relative humidity between 50% and 70%, depending on the regional climate. A traditional system would produce about 80% relative humidity.
Among the attributes of evaporative coolers cited by PATH:
  • Direct coolers cost about $700 to $1,000 installed, compared to several thousand dollars for conventional air conditioning and ductwork. In addition, their operating costs are about one-third those of conventional air conditioning — including the cost of water, depending on electric and water costs. Indirect evaporative coolers are much costlier.
  • Evaporative coolers use about one-fourth the electricity of conventional air conditioners.
  • Evaporative coolers can improve a home’s indoor air quality by drawing a large supply of fresh outdoor air through the home. However, they consume between 3.5 and 10.5 gallons of water per hour of operation.
billmhUser is Offline
Interesting info. I was not aware of the indirect process, but I am familiar with the direct coolers. I would not live without one in the SW USA. I am a little amazed at the water usage though, I could not tell the difference between the summer when the system was on and the winter when it was off as far as my water consumption was concerned. It was never something that jumped out at me, though I am sure it must have been higher.
People Online People Online: Visitors Visitors: 204 Members Members: 0 Total Total: 204
