ERV Questions
Last Post 13 Aug 2008 05:52 PM by gregj. 6 Replies.
benkingUser is Offline
25 Jul 2008 08:54 AM
I'm about to start remodeling my 1940s cape here in Maine.  We're adding two shed dormers and I'm convinced close cell spray foam is the way to insulate.  This will create a sealed envelope in my upstairs.  We heat with a woodstove in the winter so I'm not concerned about moisture during the cold season but from what I'm reading I should be strongly considering an ERV unit.  We have no central air system.  Heat is provided by wood and hot water via baseboards.
The upstairs will have two bathrooms and laundry so there will be moisture around.  I was going to proceed with good exhaust fans in both bathrooms but should I be putting an ERV in the limited crawl space I'll have in my attic?
If so where can a DIYer get an ERV?  Recommended brands?  Anyone have experience with a similar application?
The downstairs space will not be as tight as upstairs so this might help with moisture issues but I am concerned about air quality but more importantly moisture issues.
Any advice would be much appreciated!
egouinUser is Offline
26 Jul 2008 12:20 PM
We are going with an ERV from UltimateAir (www.UltimateAir.com) for our new SIP house.  It is pricier than other units on the market, but I am convinced the efficiency of the unit will pay for itself with energy savings.
I've had discussions with the manufacturer (great people).  They recommended we keep the normal bath vents/fans for local exhaust of high humidity and use the ERV for whole house ventilation.
A savvy do-it-your-selfer should be able to install one of the units.
Hope this helps.
Ed
Check out my project: www.GouinGreen.com
http://www.GouinGreen.com<br>Superinsulated SIP/Modular House (HERS = 30)<br>GSHP w/SCW, ERV, Passive Solar, Solar HW
kwalla101User is Offline
12 Aug 2008 05:39 PM
I can't speak for which brand is best-- still weighing my options-- but in my search came across this website that sells most models available direct to the consumer. When you make a decision, I'd be curious to know which make/model you chose. My current favs are UltimateAir and Fantech.
http://www.iaqsource.com/category.php/energy-recovery-ventilators-ervs/?category=946
12 Aug 2008 05:49 PM
Forgot I had these other links too, last one is article on basics of ERV's, the others are manufacturers websites:
http://www.fantech.net/hrv_erv.htm ***
http://www.venmar.ca/AfficherProduit.aspx?langue=en&id=94 **
http://www.ultimateair.com/ **
http://www.aprilaire.com/index.php?znfAction=ProductDetails&category=16&item=8100 **
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Ventilation/Energy+Efficient/Default.htm *
http://www.lennox.com/products/overview.asp?model=ERV1 *
http://www.thermastor.com/QUIET-VENT/ *
http://www.residential.carrier.com/products/airquality/ventilators/energy.shtml *
http://www.achrnews.com/Articles/Technical/0eea076944c5a010VgnVCM100000f932a8c0____
malibudUser is Offline
12 Aug 2008 09:36 PM
you should get an ERV or some sort of fresh air if your wood heat does not have an outside source of air. you will end up w/ negative air pressure; wood takes oxygen to burn . Ultimate air is probably the best whether it will pay for itself I kind doubt
Bruce FreyUser is Offline
13 Aug 2008 05:42 AM
Don't confuse ERV/HRV with make-up or combustion air.
ERV/HRV are ventilation and indoor air quality devices that EXCHANGE air.  Some of the units with 2 fans give you the opportunity to create slightly different pressure environments by varying the speed of the supply/relief fans accordingly.
ERV/HRV do not (at least in my opinion) take the place of exhaust fans in bathrooms or kitchens.  These exhaust fans are typically low volume that do not run for long periods of time and have little effect on the overall indoor air pressure environment.
If you have a combustion appliance, you really need a direct source of outside combustion air into the plant room.
If you have a fireplace that is used a lot or have a BIG gas range with BIG kitchen hood, you probably need additional make up air.  Conditioning this make up air costs money, however.
What you want to avoid is negative pressure environment that backdrafts combustion appliances and sucks in outside air and moisture through the building envelope.  I think a slightly positive pressure environment is beneficial, so when I do this in a couple years, I plan to use a 2 fan ERV and dial in more supply than relief.
The upside of the direct duct connection from outside to the return air plenum of the furnace/air conditioner is that it creates a positive pressure indoors, at least while the unit is running.  The downside is that if you don't at least run the fan, you get no outside air and there is no heat exchanger or additional filtration.
Bruce
gregjUser is Offline
I thought ERVs were only needed down south and HRVs were better for up north. If your downstairs isn't tight and you get good air circulation you probably don't need either.
People Online People Online: Visitors Visitors: 358 Members Members: 0 Total Total: 358
