Radiant heat in garage slab
Last Post 06 Aug 2008 07:42 PM by James Eggert. 3 Replies.
DwaynehackerUser is Offline
29 Jul 2008 11:24 PM
We will be building a garage and would like to incorporate as many green aspects as possible.  We would like to know if it is possible to have a thermal break under the floor with pex tubing running throughout that can support the weight of heavy vehicles?  Are there any other online references and/or books we can research?
30 Jul 2008 09:13 AM
Check with any radiant equipment supplier. They should be able to supply all the data you would need for a successful installation. Radiant is used in commerical garages a lot, especially in colder climates, so its use in a residental garage should be no problem at all.
gregjUser is Offline
05 Aug 2008 06:51 PM
EZ to do but how do you rationalize it as green?
James EggertUser is Offline
My thoughts also? The garage is an enclosed environment, should be about 20 degrees warmer than outside without heat, and its for your car? The equipment, labor and subsequent costs to run would offset your house heating admirably. If you use 2x4 walls for the garage, perhaps spending money on spray foam would be a better return?? No heat needed, and its still warmer that outside!
Green goes beyond which products you use, there is also the usage cost for what could be considered extravagant. Now I understand it's your right to spend your money as you see fit, so it is ultimately your choice!
