General Forum - Residential
Best insulation with ICF Conditioned Crawl Space
Last Post 02 Jan 2009 12:02 AM by
GBSolutions
. 1 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
banzaitoyota
01 Jan 2009 09:12 PM
Here is my situation: New Modular House installation.
2000 Square foot Conditioned crawl space:
Polysteel ICF Foundation avg height: 40"
3" Rat Slab on 6mm vapor barrier
house sits on 2x 10 PT sill; I am sealing with great stuff foam between the sill and the foundation
My Questions:
Do I place a layer of 3/4" foam on the floor?
Do I retain the loose batt fiberglass insulation between the floor joists?
Is it worth the effort/expense to place radiant barrier (FBF) under the decking of the subfloor?
When I insulate the the rim joist area: Which is a better method:
a. radiant barrier (reflectix fbf) with Foam sheets cut to fit, to a thickness to match the ICF Wall?
b. Just use the foam and forget the radiant barrier
John
GBSolutions
Would Thermal paint work?
Membership:
croccohvacusa
People Online:
