Rubble Trench Foundation
Last Post 31 Jan 2009 09:12 AM by terrymod. 2 Replies.
28 Jan 2009 10:08 AM
I'm not so sure it would be good with the soils in my area, but I wonder if anyone else is using this method instead of traditional footings:
Frank Lloyd Wright's rubble trench
28 Jan 2009 10:33 AM
Superior Walls uses clean, tamped gravel under their precast walls.  I do not know of anyone in my area using trenches filled with rubble.
terrymodUser is Offline
Have you done a soils test. Start there - and let a soils engineer advise how to make your building stable. You may have bentonite clay or other expansive soils . If you have stable soils the tamped rock works great. It is easy to do - important to drain away from the building, make sure it is tamped to the engineers specs ( say 90# compression ) then make sure it is level by using a transit.
People Online People Online: Visitors Visitors: 389 Members Members: 0 Total Total: 389
