Goy my quote
Last Post 31 Jan 2009 06:56 PM by Alton. 9 Replies.
tsufanUser is Offline
30 Jan 2009 01:42 PM
Just received my quote for spray foam insulation. The quote was for $6695.00 which includes the roof decking and all the exterior walls. My builder thinking it would be more like 9,000.00 - 10,000.00 for the job!
I think I'm getting a great deal.
aardvarcusUser is Offline
30 Jan 2009 03:34 PM
Is that a thin layer or the cavities sprayed full? How many sf is your house?
jimmy48User is Offline
30 Jan 2009 06:53 PM
Need more info what is the depth of the insulation how many sq/ft closed cell or open cell foam
30 Jan 2009 07:31 PM
Posted By aardvarcus on 01/30/2009 3:34 PM
You know, that is a good question. I hadn't even thought of asking that.
My house is 2,100 sq. feet.
30 Jan 2009 10:56 PM
Tsufan,
In my area, 2x4 wall cavities are over filled with open cell and then the excess is trimmed off so the drywall will lay flat.  However, closed cell is usually sprayed only 2.5" thick between the studs.  No trimming is necessary.
31 Jan 2009 08:34 AM
Posted By Alton on 01/30/2009 10:56 PM
Tsufan,
I believe the insulation will be applies using the open cell method. My builder has told me about the installer having to clean up all the insulation that will be cut off after application.
Is the open cell application the better option?
glenfotreUser is Offline
31 Jan 2009 10:16 AM
I talked to the Icynene engineer at the Builder's Convention in LV a week ago and he told me that they use open cell because it is flexible and will not crack if there is any movement, expansion, shrinking, etc. so it maintains its seal to keep outside air outside. Yes, the R value is lower but his contention was that the air infiltration was more critical on the walls than the R value. If you need more R value, go to 2 x 6 walls and fill them 5" deep.
31 Jan 2009 03:12 PM
tsufan are you in ontario ? if you are you want closed cell foam for the r value, open cell will not cut it in our winter climate Open cell is also cheaper then closed which is why your quote is coming in 30% less then what your builder had expected
31 Jan 2009 04:27 PM
Posted By jimmy48 on 01/31/2009 3:12 PM
I'm in Alabama.
Tsufan,
If you are within a two-hour drive of Auburn, then here is another company that might give you a bid.  This company does open and closed cell polyurethane.
Beacon Insulation
insulation at beaconinc.us
334 319-7768
People Online People Online: Visitors Visitors: 455 Members Members: 0 Total Total: 455
