It could be taking a long time (or forever) to dry because of the high vapor-permeability and high capillary draw of the concrete continuing to transfer significant amounts of water inward. It doesn't take an out & out leak for this to happen. Open cell foam is fairly permeable at 8", thickness, but it's probably only drying toward the interior. If you have any vapor-retardent materials between the foam and the air-conditioned interior, it'll be slower still. Can you describe a little better what the exterior roofing materials are, the pitch of the roof, and what's between the foam & fully-condtioned space? |
