TJI560 floor joists
Last Post 27 May 2010 05:31 AM by cmkavala. 8 Replies.
Build Green ABUser is Offline
19 May 2010 12:54 AM
Help!! My heating contractor missed with his hole sole and cut 8 inches out of my 14 inch ijoists. Is there anyway to fix this?
Could I glue and screw some plywood from each side and redrill the hole? Any assistance would be appreciated. Thanks
19 May 2010 07:02 AM
First, how many did he cut, did he cut the flanges, what are their spacings and span?
greentreeUser is Offline
19 May 2010 08:17 AM
You need to talk to iLevel (Weyerhaeuser) who makes the joists, not seek advice on a forum.
sgo70User is Offline
19 May 2010 10:18 AM
I had some problems with my plumber drilling through my main support beam and technical support where I had purchased my joists and trusses looked after everything for me. Just call them and they will help or know where to send you. They will have to make up engineered drawings and specifications. Mine did it for free but if they charge you just bill it back to your contractor.
 I learned that you really have to keep an eye on anyone that comes in to your house. My gas fitter was going to drill through the ends of 12 joists to run a 2" gas line even after I told him where it was going to go. He said he does it all the time in high end homes. I told him he's probably wanted for millions of dollars in structural repairs.
Sean
richmUser is Offline
20 May 2010 09:34 PM
BuildGreenAB,
Try this:
http://www.ilevel.com/literature/TB-816.pdf
I might get you going in the right direction.
richm
MDiverUser is Offline
26 May 2010 11:38 AM
It is usually easily fixed, but the details have to come from your supplier, don't worry, they have probably seen everything imaginable.
James EggertUser is Offline
26 May 2010 09:59 PM
The heating contractor didn't "miss" anything. He was a typical uncaring tradesperson who will never learn about his errors UNTIL he is backcharged for fixing something.
By the way, some I-joists allow almost full cutouts except for maybe a 1/2" of web top and bottom. This does depend on location relative to bearing, so check with your supplier.
SimonDUser is Offline
27 May 2010 01:56 AM
Upload a photo of the damage.
Building Designer PANELfusion, LLC Tampa, FL [email protected] "Metal SIP Advocate"
a great example of why you can't leave subs unsupervised on a job, it is the reason why frame inspections usually follow plumbing, electrical and HVAC rough inspections; to ensure the structural components have not been compromised.   I feel your pain!
I would certainly seek help from outside this forum from your engineer or the joist supplier's engineering/tech support.
But, definitely back charge him for your expenses
People Online People Online: Visitors Visitors: 468 Members Members: 0 Total Total: 468
