Spider Insulation vs Cellulose
Last Post 24 May 2010 03:55 PM by Dana1. 1 Replies.
RoberthUser is Offline
22 May 2010 02:19 PM
Which is better.   Spider is a different type of fiberglass that they claim can be densed packed and provide higher R Value, lower air flow and better radiant blocking characteristics than cellulose. Also it is not itchy.
What do you know about  spider vs cellulose.
Spider is slightly higher R at moderate delta-Ts than dense-packed cellulose, but isn't likely to impede infiltration nearly as well, and will have significantly more convective-loop losses at high delta-Ts than dense-packed cellulose (but far less than low-density blown fiberglass).
I'm highly doubtful that Spider blocks radiated heat as well as cellulose. Got any references to back that up? Glass is somewhat translucent to radiated heat, but cellulose fiber is quite opaque. Most manufacturers include additives to reduce IR translucency, but SFAIK there haven't been any recent breakthroughs on that front.
At 2"+ depths Spider is rated as a thermal barrier against ignition for foam insulations without needing to use gypsum or plywood, adding another ~ R8 to the stackup.
People Online People Online: Visitors Visitors: 455 Members Members: 0 Total Total: 455
