Untreated sill plate for walls over concrete flooring - need advice
Last Post 22 Oct 2010 03:48 PM by cmkavala. 42 Replies.
Page 3 of 3 << < 123
20 Oct 2010 04:28 AM
anyway this post has gotten way off course from the origial question, that I don't think will get answered to the satisfaction of the original poster.
SimonDUser is Offline
22 Oct 2010 03:03 PM
You are right Chris. Galvanized clips, connectors, flashings, etc... are attached and cast into concrete all the time with no problems. For the most part, the isolation has more to do with protecting the parts from 'Green' concrete which hasn't fully cured and is still damp and has a high ph which is corrosive. Galvanized steel and fully cured concrete are compatable materials for the long term under normal circumstances. Isolating one from another is just 'hedging your bets' against abnormal conditions.
Building Designer PANELfusion, LLC Tampa, FL [email protected] "Metal SIP Advocate"
Posted By SimonD on 22 Oct 2010 03:03 PM
not sure what your point is here ? or what is an abnormal condition, unless you mean catastrophic failure
People Online People Online: Visitors Visitors: 208 Members Members: 0 Total Total: 208
