Looking for small efficient HRV
Last Post 14 Jan 2011 12:49 PM by arkie6. 4 Replies.
VermonterUser is Offline
15 Oct 2010 08:58 PM
I'm looking for a small energy efficient HRV to setup in a temporary installation in our apartment. I'll probably build up a box for it and run ducts to a window. We have horrible air quality and winter is coming, so I need a way to get fresh air without having windows open. I'll also need to filter the incoming air as we're near a road and have lots of neighbors who smoke.
Thanks for any info
JereUser is Offline
15 Oct 2010 10:33 PM
First thing that comes to mind is the Panasonic bathroom fan ERV... how much do you want to spend? You should be able to hook something like this up temporarily.
http://www.kitchensource.com/bathroom-fans/fv-04ve1.htm
Is your heat included in your rent, or do you pay your heat separate? If heat is included, I would open the window a little and maybe put some kind of air filter sealed/taped to the window and turn on the bathroom fans to draw fresh air in through the filter and exhaust the stale air out the bath fan.
I built my home with the help of Pierson-Gibbs Homes, "The Hands on House". They build the shell, you finish it.
www.p-ghomes.com
matteoUser is Offline
06 Jan 2011 08:36 PM
Maybe this will help.Check it out: http://www.nollclimatecare.com/webapp/GetPage?pid=332
<a href="http://www.buildingmaterials.co.uk/Plasterboard.html">Plasterboards</a> | <a href="http://www.buildingmaterials.co.uk/Plaster-Walls.html">Plaster Walls</a>
Viking HouseUser is Offline
14 Jan 2011 04:01 AM
The most efficient air/air heat exchangers in the world are Fine Wire heat exchangers http://www.viking-house.ie/fine-wire-hrv.html How do you get links to work on the forum?
Can you afford not to build a <A href="http://www.viking-house.ie">Passive House</A>? <a href="http://www.viking-house.co.uk">www.viking-house.co.uk</a>
arkie6User is Offline
Posted By Viking House on 14 Jan 2011 04:01 AM
Click the "+Add Reply" button below and to the left of this post.  Do not use the "Quick Reply" box at the bottom of the page.
Highlight the text that you want to make a link.
Click the symbol at the top of the message reply page that looks like the earth (if you hover over it with your mouse pointer, it will show "Create Link".
Here is the Create Link symbol.
Type or paste the URL of your link in the box that pops up.
Click OK and your link should work.
People Online People Online: Visitors Visitors: 261 Members Members: 0 Total Total: 261
