Question for Dana(and others) about RF shielding stuff
Eric Anderson
| 07 Dec 2010 11:45 AM |
When I first moved in after building I had to sit outside to make cell phone calls. The house is wrapped completely with foil faced poly iso insulation(at least above ground). Last spring Verizon put in a new tower about a mile away. I am marginal now for signal inside,but radio reception sucks though. I use a cheap inside dipole antenna nowand get about 4 stations clearly. My car radio gets 20-30 stations parked in the driveway. If I wanted a simple solution to increase fm reception and get stronger cell service how would I go about doing it? I have been thinking about a simple dipole antenna on the roof running to the stereo, but I know very little about this. How about increasing cell coverage? Practically what would I do to increase signal in the house? Can I couple a outdoor antenna to an indoor one? I am guessing I only need it to get a little better as cell service marginal now, and a very strong signal outside.
Thanks, Eric |
| Think Energy CT, LLC Comprehensive Home Performance Energy Auditing |
| 07 Dec 2010 01:19 PM |
A FM antenna on the roof wired to the stereo will work. Some phones have a jack to connect an external outside antenna, but most need a repeater from someone like Wilson Electronics - get one now, they are talking about banning them.
| 07 Dec 2010 01:49 PM |
Coupling an outdoor antenna to an indoor antenna works, but it need not be anything complicated. A length of wire extending a meter or so inside and outside a window on each side of the house would be sufficient to re-broadcast 100MHz-2GHz signaling picked up outdoors to the inside of the building. The attenuation of a full foil shield is over 100dB, but drops to less than 10dB with a simple feed-through wire that's at least 1/4-wavelength at the frequency of interest on each side of the foil. Un-powered cell-phone feedthroughs can be made with a cheap coax stub antennae and a piece of coax w/connectors on cable-TV type wall-plates on both the interior & exterior of the wall. It doesn't much matter how long the antenna is for cell-phones- something stubby that won't be easily compromised by wind would be fine. For FM-band you need something longer, since it's much lower in frequency (~100MHz)/ longer-wavelength. Assuming you don't have foil under the roofing, a 1-2meter monopole antenna to coax in the attic works just fine for FM in many areas. If you need more power on the interior side re-broadcast, $10-15 VHF TV antenna amplifiers driving a 1m stub of wire will work fine (for FM, not for phone.) But of course, hooking the attic antenna directly to the receiver would work better, if it's easy to do. |
Eric Anderson
| 08 Dec 2010 09:06 AM |
Guys Thanks for the advice. Eric |
235 |
235 |
