HRV vs ERV and which one to buy?
Last Post 20 Jun 2011 06:15 PM by Duane Amundson. 41 Replies.
Page 3 of 3 << < 123
UltimateAirUser is Offline
14 Jun 2011 12:13 PM
The ERV is the correct choice. If you ever need to dehumidify or humidify - go with the ERV.... unless you have a room with a pool (open source of lots of water)... and the need is always to dehumidify (then HRV).
UltimateAir® is the industry's leading manufacturer of <a href="http://www.ultimateair.com/air-filtration/">whole-house air filtration systems</a> and energy recovery ventilators that are energy conscious and environmentally friendly.
VentolatorUser is Offline
When comparing units, check HVI data. This is the only independent testing base for ERVs/HRVs. Compare apples to apples; similar sized units and airflows. There are huge differences in sensible and latent efficiencies, as well as electrical use. Just because a unit has an ECM motor does not mean it uses less energy. The wattage listed tells the story. Check ease of installation, warranty, filter rating, maintenance requirements and access to tech support. For year round ventilation, an ERV (that is rated as such) is best.
