Steel Framed homes
Last Post 30 Aug 2011 03:44 AM by herry1. 19 Replies.
blavisUser is Offline
26 Jul 2011 04:35 PM
My parents are getting ready to build and this is the design they are choosing. I have no knowledge of steel framed buildings and would like to pass along some information to them regarding things that 'must' do on a steel framed home. http://www.kodiaksteelhomes.com/ thanks
26 Jul 2011 05:55 PM
I doubt that one can build with steel for "about the same {price} as wood". Consider concrete walls with steel for the roof.
sajid11User is Offline
27 Jul 2011 09:00 AM
Really i don't see the steel house where you build this house i want to visit this house if you send me your home address then i will visit your house.
<a href="http://www.soldsameday.com/blog/tag/buy-my-home-now/">Buy My House Now</a>
<a href="http://www.soldsameday.com/blog/learn-the-basics-to-avoid-foreclosure/">Avoid Foreclosure</a>
27 Jul 2011 09:24 AM
Steel homes require ample insulation beyond the steel studs. Otherwise, the steel will conduct energy much more so than wood studs.
27 Jul 2011 03:20 PM
Kodiak uses a slightly modified commerical red iron steel frame system, with infill steel studs. I would look at using SIPS for wall and roof sheathing over the steel frame. Much the same as with a timber frame home.
27 Jul 2011 03:53 PM
Wes, Some money could be saved by using IMPs instead of SIPs over the steel frame. If the steel studs are correctly sized and installed, there would be no need for the panels to be structural. Some companies make both SIPs and IMPs.
28 Jul 2011 07:36 AM
Alton,
My bad, I tend to use the term "sips" generically. The 'structural' part of SIPS isn't required with a steel (or wood) frame.
I don't know why companies like Kodiak don't offer insulated options in lieu of the standard steel sheetgoods they supply normally.
28 Jul 2011 11:16 AM
i know they should build ICF. I am in the process of doing it, but they dont want to.
what does IMP stand for?
and what would be the recommended insulation process on a steel framed house?
28 Jul 2011 12:04 PM
IMP is Insulated Metal Panels. Non-structural. Cladding and insulation only. To be used only when structural elements are already in place.
28 Jul 2011 12:10 PM
Does IMP for roofing allow a greater span than sheet steel alone (ie, greater spacing on the structural elements)?
29 Jul 2011 08:21 PM
jonr,
To answer your question about spans. It depends on the particular IMP being used. Spans depend on both top and bottom sheet profiles, the guage of the metal, and the thickness of the insulation. Most are designed for use on standard steel framed buildings. But I don't know of any company that supplies both IMPs and red iron frames. More investigation is required.
30 Jul 2011 05:36 PM
Looks like it does. Ie, foam bonded/laminated to steel has greater strength than the same steel lying loosely on the same foam.
30 Jul 2011 06:18 PM
It is more economical to simply use Steel SIPs instead of red iron frame and IMP
30 Jul 2011 08:44 PM
Chris, I agree. I have built with red iron and it is expensive.
Jerry D. Coombs, PEUser is Offline
25 Aug 2011 10:54 AM
blavis,
This obviously spawns a lot of other discussion, but to offer some input on your original question: Alton hit the first point dead-on with thermal conduction. I've seen this construction where condensation lines are visible along each exterior stud in the winter. A thermal break is needed. It's often done with an inch or so of rigid insulation between the sheathing and exterior finish, but can also be installed on the inside. In some regions, commercial construction is almost all steel stud framed. They usually have the exterior insulation thermal break.
Another concern is to make sure they secure the sill plates properly. The ones for the shear walls should be a heavier gage, and/ or have the anchor bolts tie directly to the walls.
Make sure that the electrician either uses conduit or puts the grommets on ALL holes he pulls the wire through.
Make sure you have no copper pipes touching studs or you'll get galvanic corrosion.
Make sure they use the proper fasteners (drywall, etc) so you don't get unexpected corrosion.
If they weld any connections, have them paint over the weld with a good rust inhibitor.
Light ga metal framing is cheaper than wood in some regions. Just price around, but consider all of the above into the costs. That's all I can think of off the top of my head. May come up with others later.
<br>You can have with quality; You can have it fast; You can have it cheap.
Pick any two.
Lee DodgeUser is Offline
25 Aug 2011 01:47 PM
A friend here built a steel framed house, and was unhappy with the conduction of noise throoughout the house. I don't know if that is always a characteristic of steel-framed houses, or if it can be avoided.
Lee Dodge,
blossom2347User is Offline
26 Aug 2011 02:09 AM
Yeah it is not only expensive but also noisy. So avoid it as much as you can.
SPF Roofing
<a href="http://www.oceansevenroofing.com/Services/Insulation/Insulation.html">SPF Roofing</a>
26 Aug 2011 09:19 AM
Steel framing is widely used in office buildings, but a lot more moisture is generated in a house than an office building (from showers and cooking). Therefore, more care must be used to avoid moisture issues with the steel when used in a home compared to an office. Of course, the same can be said about wood framed buildings that will easily mold and eventually rot if moisture issues are not addressed in the design and operation.
Lee Dodge,
26 Aug 2011 10:15 AM
lee; a good example of thermal conductivity of wood framing members
herry1User is Offline
Lee Dodge i agree with you.
blavis If you want to use steel frame.Its very good,Because you make your home for your self.Bur please frame use just for walls,not for roof.You make roof with steel sheet.
Huntsville home improvement
People Online People Online: Visitors Visitors: 239 Members Members: 0 Total Total: 239
