General Forum - Residential
Slab Foundations
Last Post 29 Jul 2012 06:07 PM by
Lbear
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Lbear
29 Jul 2012 06:39 AM
Typically a 4" concrete slab is used for a foundation but with a 2-story ICF/concrete home, I was wondering if one needs to increase that foundation thickness due to the added weight?
For a mild climate area like Chino Valley Arizona, does one need to utilize EPS insulation underneath the slab? Or just pour the slab onto compacted AB?
cmkavala
29 Jul 2012 07:11 AM
Lbear; the slab typically does not bear the weight of the house, the footers do and codes require bigger footers for 2 - 3 story homes, your architect/ engineer should advise you on this
Chris Kavala<br>
[email protected]
<br>1-877-321-SIPS<br />
29 Jul 2012 09:38 AM
In a thickened edge slab, the edges are thickened for this reason.
Lbear
I also read that doing "cut and fill" on slab-on-grades is not recommended for areas with seismic issues. Problem is that it is next to impossible to find a completely flat and level spot that requires no cutting and filling.
Membership:
croccohvacusa
People Online:
