Posted By Alton on 07 Sep 2012 09:21 PM
What is the zip code for the location of the pole shed? Are you trying to keep heat in or out? Spray foam will usually stick to almost anything. Closed cell foam would add strength to the building.
zip code is 67575, Its real hot in the summer here and real cold in the winter
