1. dig 4" of dirt out of the shelf floor, install 2" of EPS or XPS, taping the seams. Install 6 mil poly and tape those seams. The poly should extend up onto the wall. then pour a 2" concrete floor. Note that the foam must extend up the wall enough to disconnect the new floor from any other floor or wall concrete. 2. Install Polysio aluminum faced foam - 2" minimum - on the concrete walls with foam adhesive (this must have a fire barrier over it unless you use Thermax brand) Foam the seams, the top edge and the bottom edge, then tape them. 3. Glue 2" of XPS or EPS foam on top of your cellar floor, tape the seams. Pour 2" of concrete over this if possible, installing a layer of 6 mil poly (taped) between the foam and the concrete. If pouring a new 2" floor over the existing floor is impossible, you can cover the foam with exterior grade plywood. If you can install the 2" of concrete in the main basement, put strips of 2" foam around the edges so the new concrete does not touch the cold concrete. This prevents a "thermal bridge" which will draw heat out of the concrete. Moisture comes up from the ground below the house, and through the walls, through the concrete, so you must prevent that moisture from entering the basement. Adding a layer of foam does two things: it isolates the basement from the cold concrete, lowering condensation levels, and when installed under concrete which is isolated from the walls, allows the new concrete to remain at or closer to room temperature. Polysio aluminum faced foam is an excellent moisture barrier on walls, but should not be used under floors where it can absorb water. XPS (Styrofoam) is permeable, but less so than EPS, will help keep ground moisture out of the basement, and can be used in potentially wet areas. I had a very damp - occasionally wet - dirt floor basement; I installed 2" foam, 10mil poly and concrete. the basement now is usable for storage and workshop, with a stable, comfortable heat level. And it increased the comfort of the whole house by a huge amount. |
