Framing internal/external corners with rigid exterior insulation
Last Post 24 Mar 2014 09:22 PM by FBBP. 3 Replies.
SurfsupUser is Offline
14 Mar 2014 07:40 AM
Does anyone have a source/link to get some details for a framer that has never done this before? With 1.5" offset of an inside corner and outside corner, I assume there might need to be a change in the framing so the furring has something to screw into?
Bob IUser is Offline
14 Mar 2014 12:36 PM
you can install a strip of plywood in liew of the strapping that is wide enough to reach back to the framing.
14 Mar 2014 10:21 PM
I assume you are referring to an outside corner. Is there anything that needs to be done for aninside corner?
FBBPUser is Offline
An inside corner would normally be framed to support the sheathing, so there should be support for strapping. It also depends on the detail you use for the inside corner of your cladding.
People Online People Online: Visitors Visitors: 488 Members Members: 0 Total Total: 488
