Ext Rigid OUTIE Window
Last Post 15 Jun 2014 07:29 PM by Surfsup. 6 Replies.
SurfsupUser is Offline
14 Mar 2014 08:03 AM
Curious if I have this right. Please see detail I mocked up at link below
Tyvek would go between the blue furring strip and green insulation, right?
In order to seal the window in, though, I assume I would caulk the heck out of the furring strip/Tyvek interface? How would I best do this?
I assume I would caulk the windowflange and tape it as well?
Any particular caulk I should use that won't dry out over time?
http://chicagocadcam.com/ChrisHahn/house/ExteriorRigidWindowOpening.PNG
FBBPUser is Offline
24 Mar 2014 09:20 PM
***In order to seal the window in, though, I assume I would caulk the heck out of the furring strip/Tyvek interface? How would I best do this?***
I would use another strip of tyvek over top of the nail flange/ furring strip and tape it to the nailing flange and the original tyvek.
26 Mar 2014 05:59 AM
At the top I was planning to do that, I suppose I can do it all around but since the furring sits higher the corners will be tricky. Anyone else have any more input?
21 Apr 2014 07:44 PM
What if i cut the "X" in the tyvek, then furred it out, and folded the X pieces backinothe opening over the furring, and taped the edges? I am mostly concerned with the top of the indow, as water runs own the tyvek. I feel taping might not hold here and wter can eventually work under he tape.
How do you guys do this? Did anyone look at my detail?
FBBPUser is Offline
21 Apr 2014 08:53 PM
Surf - if you don't want to rely on tape, cut the original house wrap about 2" above the wind and the width of the window. Then take a six inch wide strip and slide it UNDER the original and over the nailing flange. You can then tape the joint for air seal but because the two pieces overlap in the right direction, water won't penetrate the joint. The only suspects will be the two corners of the joints.
22 Apr 2014 05:10 PM
FBBP yea I thought of that this morning too, to have it shed down another piece slid under but taped over the furring to the nail flange. I can also do this after the framers install the windows. So it'll happen like this.
Framers frame the house.
While they frame, i install 1-1/2 inch XPS
Framers wrap house.
I furr out the windows doors
Windows arrive and framers install them
I come in after and cut the tyvek a few inches above the top furring strip and slide under another piece of tyvek and tape it over the furring strip and nailing flange
Anyone think of any issues with this?
Here's what we're doing. They frame, sheathe, then we install the foam while the wall is down and tack the Tyvek. Put a few extra cap nails in there to hold the Tyvek, then stand up the wall. Seems to be working well so far - just did first floor deck and one wall so far. I put the foam on the rim board everywhere.
When I attach furring strips, any need for liquid nails between the furring strip and the tyvek? I assume no.
People Online People Online: Visitors Visitors: 202 Members Members: 0 Total Total: 202
