Chased down another local source for foam insulation today.. now this is EPS not XPS and my understanding (please correct me if I'm wrong) is that the EPS is a better performer as the temp falls while XPS does not and... EPS is more vapour permeable which is needed in my retrofit over existing 2x6 with a 6 mil vapour barrier on the interior.
they have a variety of sizes all priced at 10c/sqft per inch so
2 inches is 20c a sqft etc..
I found 2, 3 and 4 inch thick EPS a mix of type 1 and type 2 (not sure if I should prefer one or the other) but in quantities that will easily look after my requirement (now I think its 5000 sqft at 4").
800 sqft under the new pad = 800
180 ft of perimeter wall 4 ft horizontal frost protection = 720 sqft
180 ft of perimeter wall 2 stories tall = 2880
totals 4400 so with a 10ish% fudge factor =5000.... 5000 x 4" @.10/inch $2000 = a BARGAIN
Before I move on I have to confirm...
is 4 inches EPS under the slab enough
is 4" on the exterior walls of both existing and new construction enough...
I know there is a rule of thumb about 2/3 of the insulation being outside the wall but with R20 in the wall I would need R40 on the outside...that seems unlikely??
