Posted By dpj012 on 03 Apr 2015 03:43 PM
Thanks for your replies, the SIPs are styrofoam/polysterene sandwiched in OSB on the roof and exterior walls. The noises vary from loud bangs similar to hammering but with no rhythm, on the wall to softer as if someone was bumping into the wall. Since the weather outside has warmed up in the last day or two they have dissipated a bit.
Since they are EPS SIPs then I assume they are probably Premier SIPs?
How long do the sounds last for? Is it a momentary thing or does it do it all day long?
Did they use any type of sound attenuation in the walls or roof? (e.g., decoupling of SIP with clips and hat channels, 5/8" drywall, etc?)
It's best to answer each question posed directly so we can get a better understanding and help you address your problem.
