Ceiling insulation access
Last Post 05 May 2016 09:08 AM by ronmar. 3 Replies.
JubalUser is Offline
04 May 2016 04:41 PM
Considering a single level ranch house with a full hip truss roof and large overhangs. How does one gain access to blow in ceiling insulation without using pull down attic stairs ?
Bob IUser is Offline
04 May 2016 04:45 PM
either through the attached garage, or through the insulated, weatherstripped attic hatch that you need to install anyway (it's a code issue) for emergency access.
smartwallUser is Offline
05 May 2016 08:10 AM
As Bob I said except locate it in a closet ceiling, like they did in the old days.
ronmarUser is Offline
Yep, you need to provide a code approved opening(certain dimensions to fit between common roof truss spacing). With a hip truss roof, about your only option are those mentioned above. With a gabled truss roof, the access can be outside thru an opening in a gable end...
People Online People Online: Visitors Visitors: 146 Members Members: 0 Total Total: 146
