Posted By ronmar on 28 Jul 2016 11:19 PM
Lbear, you didn't answer if the wall with the garage door is the load bearing wall for the roof or not? If it is not the load bearing wall I agree with MTicf that you can make a very strong CC header with 36" of uninterrupted height to work with... Even if it is the load bearing wall, depending on the roof load numbers you need to meet, it may still be possible. What are your roof design requirements and the span of the roof joists?
It's not bearing the roof. The roof loads are low, around 20PSF snow load and around 20PSF dead load.
The glulam roof joists are 24 feet wide
