New Home in Iowa 2x6 exterior Advice Ranch/Full Basement
Last Post 28 Jan 2017 02:25 PM by crabapple. 92 Replies.
Page 5 of 5 << < 12345
rgonyerUser is Offline
24 Oct 2016 10:27 AM
Footings are poured! Things are moving now. Builder promised to caulk underneath the framed walls, and the OSB to the studs. Seems like a good start.
24 Oct 2016 11:03 AM
[URL=http://s346.photobucket.com/user/rgonyer/media/New%20House%202016/10-20-2016-1_zpssboj8glr.jpg.html][/URL]
11 Nov 2016 11:39 AM
Posted By BadgerBoilerMN on 04 Oct 2016 11:02 AM
This is the standard in N. America for sub-slab insulation.
http://www.menards.com/main/building-materials/insulation/insulation-panels/f250-2-x-4-x-8-r-10-extruded-polystyrene-insulation/p-1444450504310-c-5779.htm?tid=-9197785561416543961
Anyone else have any suggestions for underslab? This stuff is almost a buck a sq. ft. Would love to find something lower cost if possible. I've been trying to find used/reclaimed without any luck so far, but I need to get it pretty soon.
Bob IUser is Offline
11 Nov 2016 11:43 AM
We buy EPS for less than half that. Look at commercial roofing outlets like ABC, Beacon Sales etc.
11 Nov 2016 11:54 AM
Posted By rgonyer on 24 Oct 2016 11:03 AM
That is a LOT of corners & bump-outs, which will increase your framing fraction to well over 25%, maybe even more than 30%. that makes it harder to air seal too, especially at the non-perpendicular corners.
The high framing fraction would make exterior foam an even more signficant performance improvement than on a house with 8 or fewer corners (A "T" topology or simpler.)
11 Nov 2016 11:57 AM
Coming together - Great!
TWhiteUser is Offline
17 Nov 2016 10:49 AM
I would use sill seal under your bottom plate instead of caulk.
17 Nov 2016 10:53 AM
foam sill seal is junk; it does not seal. Use these EDPM construction gaskets, which run about $1/lf: http://www.conservationtechnology.com/building_gaskets.html
drewintoledoUser is Offline
02 Dec 2016 09:23 PM
Instead of caulking the sheathing, you might enjoy a product such as "ecoseal" which is applied within the inside of the stud bays and along the sill plates with a high pressure airless sprayer. If you search youtube for "ecoseal", you will find demonstrations on how it penetrates into the cracks. If you're persistent about using a caulking product, I've learned from the chatter on this board and GBA that you should be sure to use a high quality polyurethane caulk and not your typical paint-on low quality caulk.
I am enjoying this thread as I will be building next year or the year following.
03 Dec 2016 05:01 PM
I wonder how many people using caulk/sealant even know what "3 sided adhesion" is or why a bond breaker is necessary in a fillet joint.
greentreeUser is Offline
04 Dec 2016 09:58 AM
Maybe 1 in 20, and of those, myself included, half or better ignore those rules most of the time. You really gonna make a tiny bond break at a floor to tub intersection? Backer rod is at least easy, corner bond break not so much in smaller residential joints.
crabappleUser is Offline
It worked for me & I cut & pasted it.
People Online People Online: Visitors Visitors: 163 Members Members: 0 Total Total: 163
