General Forum - Residential
Free Great Stuff foam Gun
Last Post 27 Nov 2016 05:10 PM by
ronmar
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
T-Sox
26 Nov 2016 02:20 PM
Not sure if this is the right place to put this or if anyone will care but here goes. I was in Home Depot today and they had a carboard display set up with the Pro 14 gun and foam. If you buy 4 cans of foam you get the gun free. Hopefully this helps someone else.
richm
26 Nov 2016 06:15 PM
Hey T-Sox,
I saw that Thursday; it is a very good deal considering I paid $36 for just the gun a couple years ago; I think it is the same model; works fantastic as long as you clean it right after you're done using it!
RichM
ian_upton
27 Nov 2016 07:53 AM
Great deal. I have 3 new guns sitting in boxes. Looks like Christmas presents now!.
Ian.
1840's Timberframe House
- Air sealed attics + R60 cellulose
- 2 part foam in crawl space and band joist
kenora
27 Nov 2016 01:52 PM
FYI...just let a glob of foam harden at the tip when you are done.... no need to clean it if you leave the can on the gun! When you are using the gun the next time (I've been as long as 6 weeks) you just remove the glob of dried foam with a razon knife and away you go.... I used up multiple cans of cleaner before I learned this trick...
kenora
27 Nov 2016 01:53 PM
If you remove the can after working you MUST clean it or start a new can ASAP
ronmar
Yep, I only clean when I take the can off. Just shave the foam off of the tip and you are good. I did replace the nylon checkball with a chrome ball bearing...
Membership:
croccohvacusa
People Online:
